Ah, that's right i forgot you're on the Pro-Kit. Here are the rates:I don't know what the spring rates are with the Pro-Kit, probably too low because the car moves quite a bit over bumps. There is a dip I go over every day leaving work, the Acura I have to go way slow or I hear it rub, the Mitsu I can fly over it and the dampening soaks it up.
I was thinking about going with Fortune 500s?
https://shop-fortune-auto.com/colle.../acura-tsx-cl9-2004-2008-500-series-coilovers
I haven't decided what to go with. I definitely don't have the budget for this car to go big money.
I'd also like to go with the following but I haven't done enough research to say definitively if I'll do it or not.
https://www.heeltoeauto.com/bushing...8-acura-tsx-all-flp.compliancebearing.pr.html
https://www.heeltoeauto.com/js-raci...7-cl9-cl7-ff-roll-center-adjuster-fcj-e2.html
On top of the suspension, I'll have to do the axles because I'm getting some vibration, and while I have it all apart I should do the upper ball joint as well. Its throw money parts at a car I like or buy something new and make payments.
Heard great things about Fortune Auto. A buddy of mine on here and the FB groups is selling his brand new set with upgraded swift springs. 14k/10k I think. Maybe 200 miles on them.. think he was asking $1,500. Richard Dan is his name. I'd check them out.Those rates are pretty low, I guess that's why I get so much suspension travel over dips and such.
I know you are affiliated with Eibach, is there a set up you recommend from them that would be in the $1500 range or is that not enough to dip into that sweet sweet Eibach pool?
I've heard a lot of good about Fortune as well, they don't make the 510s for the TSX, only the 500 series, but they have a lot of options if you want different rates and such.
Can you explain your rationale on the higher rates on your car? From what I understand you'd want higher rates if you were pretty low and didn't want the travel that could possibly damage the car? I don't/will never track the car, nothing even close to me to play around and I don't have the time or money. And I'll end up raising the car a little so I shouldn't need real high rates?
Thanks for the intel on the ball joints, I'll just go with OEM then. Seems once a month I see a post on the FB group with a balljoint failure, so I figured while the suspension is apart swap them out. Any recommendations for the upper joint? I thought about those Skunk upper control arms but I don't think I'll need that much adjustment so it might be better to just swap out the ball joint, I thought that maybe a new arm with everything in it might be better so I get new bushings. Any recommendations?
Unfortunately, we do not have any coilovers we make for the TSX. I went with a Ground Control set up when I first started putting my car together before months and months of convincing our engineers to make me a single set.I know you are affiliated with Eibach, is there a set up you recommend from them that would be in the $1500 range or is that not enough to dip into that sweet sweet Eibach pool?
I went with the higher rates because my suspension is more track focused. I wanted the car to react quicker to weight transfer on the track. If you don't plan on tracking or anything near that level of performance then your needs will be much different.Can you explain your rationale on the higher rates on your car? From what I understand you'd want higher rates if you were pretty low and didn't want the travel that could possibly damage the car? I don't/will never track the car, nothing even close to me to play around and I don't have the time or money. And I'll end up raising the car a little so I shouldn't need real high rates?
I'm using the Hard Race upper arms and I'm happy with those so far.Any recommendations for the upper joint? I thought about those Skunk upper control arms but I don't think I'll need that much adjustment so it might be better to just swap out the ball joint, I thought that maybe a new arm with everything in it might be better so I get new bushings. Any recommendations?
Yes, KW only has v1 for our cars. ST is essentially the same as v1 but with zinc-coated steel body instead of stainless steel.Thanks for the spring rate recommendations.
Is it the Variant 1 KW set you recommend?
The bushing kit was $150-$160 or so iirc. I pressed them in myself at my family's shop, but I don't see a shop taking more than an hour to do the job - I'd be shocked if a shop charged more than $75-$100 to do the work.What did you pay for the bushings then the pressing, if you have that knowledge handy, otherwise I can google.
Sounds more like you are talking about the PCI bearings, not the Spoon rigid collars?sonyfever said:Gotta chime in on rigid collars.
It works wonderfully, but only when powertrain/suspension/steering components all work correctly. Anything wrong, and you will feel it. Not necessarily a bad thing if you have the time and resource to keep the car in top shape.
As for noise, my car had too many issues in the past year that I lost reference. But I think it does not increase a lot, on the assumption that all other components run normally.
