Not specifically, although the Nav module is always suspect for stuff like this, as well as bluetooth if you have one (or installed aftermarket).
You can buy an inline fuse jumper which will allow you to check the current flowing through individual fuses to narrow it down. You'll need a somewhat heavier duty ammeter, the typical home/garage voltmeter can't handle the amount of current it's likely pulling to drain the battery.
Be aware when testing each fuse it's possible that the load will be deactivated when you pull the fuse to hook up the tester. For that reason I'd switch the key on and then off again after hooking up the tester but before taking a reading. You might even have to start the engine. Leave the power on long enough for accessories to boot up. So a bit tedious.
This gadget has a built-in ammeter designed to handle most auto accessory loads...
Buy ESI 306B 30 Amp Fuse Buddy ATC Tester: Fuses - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
