If you have a stuck stat, you’d likely get a code for “cooling system performance”. My 04 read right in the center, my 10 reads 1/3 at normal op.
If you have a scanner or one of those generic live data dongles to use with your phone, you can see the actual coolant temp as reported by the temp sensor. Depending on ambient temperature, you should see the temp reach operating temp (around 200 f) within 5 minutes of driving or so. If it takes considerably longer (again depending on ambient temperature), and also hangs low 170’s 180’s for a long period of time, the thermostat could be weak or stuck open.
My 10 has 162k and still on original stat.
