1 - 9 of 9 Posts
WAT DO?
I just ordered my wheels, which are non stagger 18x8 +35ET
I was originally planning on ordering 225/40 tires, but I'm wondering if anyone has run a 225/45 series in a similar offset. Id like as much meat on the tire as I can fit. I am already planning on getting the fenders rolled for added clearance..
Anyone else running 225/45?
WAT DO?
If you're not going to slam, I don't see why not. I was actually thinking about this on my set of 18x8 +36. When with a 215/45 instead so I can go lower.
Yeah I figured as much, I'm pretty low right now (no finger gap in front and about 1/2'' gap in rear (215/50/17)
Im not sure if that qualifies as slammed or not, I'm not tucking :p
WAT DO?
maybe think about 235/40/18? It is closest to the OEM diameter so your speedo will be more accurate.
I don't think that width will fit on a 8 inch rim running a 35 offset..
WAT DO?
Discussion Starter · #7 ·
Was trying to fit a good size tire with my drop, im lowered quite a bit and would like something that can clear the inside of the fender
WAT DO?
Discussion Starter · #9 ·
Very Helpful link!! thank you. 225/40 would be the most ideal, I didnt think the 45 series was larger than oem!
1 - 9 of 9 Posts
