I'm soon going to be replacing my clutch and flywheel with an RSX Type-S flywheel and Exedy OEM replacement clutch. Also thinking about going with an OEM Honda LSD and possibly new 6th gear. I few questions for those that have done such swaps:
1 - From what year Civic Si do I source the LSD?
2 - Although I don't want to mess with ratios of gears 1-5, is the Civic Si's 6th gear condusive to better gas mileage on the highway? I do mostly highway driving at 80mph, so this may be beneficial.
3 - If the Si's 6th gear would be condusive to better gas mileage, can I only swap the 6th gear, or do all gears need to be swapped?
4 - from what year Si do I source the 6th gear?
5 - How will swapping the 6th gear affect the speedometer accuracy?
Thanks in advance...
