im thinking about getting the Aspec springs, its not a huge drop and it should be nice for performance. i want any changes i do to be perfect. so im wondering if a cambering kit is needed for the Aspec.
also, im going to be putting on 19 inch rims once the winter is over. so if i have larger rims (ill try to keep the over all diameter close to stock, as in shorter rubber) and i have new springs, which way and which things are going to be affected?
i think ill need a cambering kit, although i hear its not needed with aspec but ill have new rims... and ill need an alignment.
overall, what should i look for, should i need a camber kit, and is there any changes with a rear sway bar in regards to problems that could occur. the rear sway is another consideration that id throw in.
Thanks in advance, please help
TSX Cman
TSX Cman
