1 - 2 of 2 Posts
Even with the AC off... very cold air comes out when the temp is set low.... It feels like the AC is on.. even though I haven't pressed the AC button.
Discussion Starter #2
I have the answer now.. The system is a climate control type so as you turn the temp down.. the AC comes on automatically. ONLY if you press the AC button do you get the display
"AC on" or "AC off"....... now that I know I am set.... Often it may be only in the 50s but when the car is closed up.. it will be warm inside... so turning the temp to low and turning on the fan will blow cool outside air without running the AC... as long as I see the "AC is Off" display
1 - 2 of 2 Posts
