1 - 6 of 6 Posts
Hello everyone,
I just noticed that after my car stands unused for few days and when its time to turn on the AC it makes a loud knock noise just when i press the AUTO button on the climate control. Any ideas? is the compressor dying or its just loose?
Whatever it is, knocking from the compressor can't be good. IMO, second guessing will not provide any solutions, best to take it in and have the dealer look at it. Let us know what you find out?
Luckily, warranty should cover it.
If I am idling and press the auto is makes a knock noise also, if I press it on / off on / off every time it makes a knock when turns on. My old cars used to do the same so I am not worried, should I be?
Sounds like the compressor clutch may be sticking but that's only a guess. Since you live somewhere hot and sticky (no pun intended), I would take it in and have it checked.
In my experience the problem with these type of issues is they only get worse over time and when it inevitably fails... it will be somewhere inconvenient and be even more expensive.
One last thought is whether you plan on keeping the car or not. If you do, get it fixed, if not, I would still consider fixing it as anyone else buying it will offer you considerably less if isn't working right.
Good luck, hope this helps...
Donating TSXCLUB Member
When my was failing, it was making click click click, like when you turn it on, it clicks 2-3 times..
Damn right, AC is non availability is not an option where I am.(f)(l)(a)(
1 - 6 of 6 Posts
