My A/C is making a 'whooping' sound' so I took it to the local Acura Service Center. They confirmed that it's low on Freon and the noise is emanating from the expansion valve. They quoted $1600 to replace the line and expansion valve. The explanation for the leak was that the OEM aluminum line was deformed where it mates with the valve and o-ring.
To provide some background, they replaced the Schrader valves in July 2015 when the air conditioning first started leaking. The symptoms manifested as warm air from driver's side and cold air from the passenger side. They use NAPA valves (since Honda doesn't sell just the valves and o-rings) and mentioned that they might start leaking again.
For today's visit, the Tech test fitted some new NAPA valves and said that it was still leaking (just not as much) and recommended, at a minimum, replacing the line. It's $300 for the part and $500 in labor. They also charged an $80 diagnostic fee for today's visit but would deduct it from the total bill if they do the work.
Has anyone encountered this issue and come up with a fix that doesn't include replacing the line? If not, does it make sense to replace the expansion valve if it only makes noise when the Freon is low?
