from car and driver
The 2004 Acura TSX sedan will be priced at $26,490 for both the 6-speed manual model and the 5-speed automatic model, when it goes on sale this week.
The Acura Navigation System with Voice Recognition is the only available factory-installed option and is priced at $2,000 and the destination and handling charge is $500.
The TSX uses a 2.4-liter, 200-horsepower engine and a drive-by-wire throttle control system. It slots in the Acura lineup between the RSX sports coupe and the 3.2 TL luxury sedan. Acura says that the TSX is designed to compete with other premium sports sedans from Europe and Japan.
2004 Acura TSX Highlights:
2.4-liter DOHC i-VTEC aluminum alloy 4-cylinder engine
200-horsepower at 6800 rpm and 166 lb-ft of torque at 4500 rpm
Drive-by-wire throttle system
Programmed Fuel Injection (PGM-FI)
Choice of 6-speed manual transmission with magnesium housing or 5-speed automatic transmission with Sequential SportShift
LEV-2 exhaust emission control system
110,000-mile tune-up interval
4-wheel-independent double-wishbone suspension with multi-link rear
Torque-sensing, variable power-assisted rack-and-pinion steering system
17-inch alloy wheels with V-rated all-season performance tires
Vehicle Stability Assist (VSA) with Traction Control
4-wheel disc brakes with Anti-lock Braking System (ABS)
Dual-zone automatic climate
Steering wheel-mounted audio control system and cruise control switches
High Intensity Discharge (HID) headlights
http://www.caranddriver.com/xp/Caranddriver/dai/2003/april/20030411_dai_acura.xml
