Hey everyone!
I'm new to the forum and I'm currently working on the BBK upgrade from the TL-S. I'm sure everyone, including myself, have done hours of research on how to make it work but I wanted to share my process and what I've done so far. So here we go!
I wanted to go with the TL-S calipers and use my tsx spindles but decided it wouldnt be a safe approach and to have the headache of using a rotor that just would be 100% perfect fit, I went ahead and bought the the following from a local:
-Acura TL-S Brembo Calipers
-Acura TL-S Spindles w/ sensors, cut brake lines, ball joints.
-Acura TL-S Rotors
Here is what they looked like then I got them:
I didn't like how the rotors looked so I thought I would resurface them to see how bad they were:
In the mean time I took apart the caliper hardware to see what else may need to be replaced/cleaned:
Then I proceeded to replace the bearings along with the lower ball joints since the TL-S are much bigger than the TSX ones:
Popped out the Hub and and the studs because I plan on installing extended studs in the future:
-Acura TL-S Rotors
