I have an Acura TSX 2008 model. All of a sudden the check engine lights, TSA lights are on. It also reads check transmission system. When the diagnosis was run, it shows that A solenoid is not receiving ample power and codes read are P9062. Need help on how to get this fixed.
Any help is appreciated! Thanks.
2008 TSX auto
I'm not aware of a TSA light in our TSX. I assume you mean VSA. The VSA light illuminates often when there are other issues. Since you have a code you follow the troubleshooting process for that code in the service manual. I think there is a copy somewhere in this forum. You're in luck; all the solenoids for this transmission are external and relatively easy to replace if required.
Yes my bad.. it’s VSA light.
good news is I just got a call from my mechanic shop saying the harness was chewed on by a rodent. And they found another harness to get this fixed up.. nothing major..
and thank you for the quick response.. really appreciate ur feedback.
Wow
Best possible outcome given the symptoms!
