1 - 20 of 43 Posts
Approved Trade Vendor
Acura TSX Fog Light LED Bulbs
We carry LED bulbs for replacement of your TSX' fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your Acura TSX's fog lights a nice bright white that closely matches factory HIDs! Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Lower brightness than factory, but still provides the crisp white, modern color of LEDs.
XP80: 510 lumens. Similar brightness to factory.
SLF: 850 lumens. Much brighter than factory. These are bright! USA Made!
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Acura TSX).
Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
2004-2014 Acura TSX Fog Lights
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
, Admin, Marketplace
Are these brand new to the market or have they been out but just not available for the tsx ?
We just released them last week, and I'm now getting threads up for new vehicles.
These are very special LEDs
Nick C.
Are these rated like 4k or 5k ?
All of our "cool white" LEDs are rated at ANSI-standard 6500K. (Matches 6000K HIDs quite nicely).
The XML2 fog lights will be available in 3000K (pure yellow), 4000K (natural white) and 5000K (true white) by the end of the month.
Thanks!
Thanks!
Okay thanks
Nice I am waiting for the 5k to be available :)
Any idea when you will get the 5k in yet ?
Okay thanks for the update
Discussion Starter · #12 ·
Our 1,420 lumen XML2 LED foglights are now available in 4300K and 5000K colors!
Give us a call if you have any questions! (314) 205-3033
Thanks,
Nick C.
Thanks,
Nick C.
Yeeeeeessssssss thanks for the update :tu2:
Got mine today :)
Thanks for all your help !
Discussion Starter · #19 · (Edited)
Whoa...can you make those LED foglight housings for the 04-08 TSXs? With stronger glass than the OEM fogs since they always crack
1 - 20 of 43 Posts
