Here is the detailed info on the TSX recall for the trunk wiring harness. The recall begins October 1st 2004.
Make : ACURA Model : TSX Year : 2004
NHTSA CAMPAIGN ID Number : 04V429000 Recall Date : SEP 02, 2004
Component: EXTERIOR LIGHTING:TAIL LIGHTS
Potential Number Of Units Affected : 40060
Summary:
ON CERTAIN PASSENGER CARS, THE WIRE HARNESS LOCATED IN THE TRUNK HINGE AREA IS NOT ADEQUATELY PROTECTED AND OVER TIME COULD BE DAMAGED WHEN THE TRUNK IS OPENED AND CLOSED.
Consequence:
A DAMAGED HARNESS CAN CAUSE A BLOWN FUSE, A SHORT CIRCUIT AND IT CAN RESULT IN A LOSS OF LICENSE PLATE LIGHTS, BACK-UP LIGHTS AND TAIL LIGHT FUNCTION. LOSS OF A TAIL LIGHT COULD REDUCE VISIBILITY AND INCREASE THE RISK OF A VEHICLE CRASH.
Remedy:
DEALERS WILL INSPECT THE HARNESS AND IF ANY DAMAGE IS FOUND, THE HARNESS WILL BE REPLACED. IF NO DAMAGE IS FOUND, DEALERS WILL INSTALL CORRUGATED PLASTIC TUBING OVER THE HARNESS TO PREVENT FUTURE DAMAGE. THE RECALL IS EXPECTED TO BEGIN OCTOBER 1, 2004. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
HONDA RECALL NO. P45. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Another sticky worthy thread.
Summary:
Consequence:
Remedy:
Notes:
