1 - 9 of 9 Posts
I love my CL9!
I'm just curious to know what type of results you get with an 06 cat. Please post your readings and list your mods too if you wouldn't mind. Thanks.
If it's an 06 stock cat it should pass no problem. I just did mine last year but mine is an 05.
I love my CL9!
I'm sure it'll pass. I'm just curious to see what the readings are. It's better flowing than the 04/05 cats so I assume the readings would be closer to the limits.
Just got my 04 done last week. You can perhaps use it as a reference.
RT cat, DC header, UR pulleys, Comptech Icebox. Stock exhaust
I did a 2 speed test as it was too low to go on the dyno.
2500 RPM IDLE RPM
HC PPM Limit 150 Reading 26 Limit 150 Reading 102
CO% Limit 0.70 Reading 0.03 Limit 0.70 Reading 0.53
No problems with passing.
Everything on. This is the second time i did a Drive Test emission. Never removed any mods. Passed them both on the 1st try.
I love my CL9!
Discussion Starter #9
Good to know. I guess for me, it was my combination of the high flow cat and the s/c that caused me to fail.
1 - 9 of 9 Posts
