1 - 14 of 14 Posts
mymothercountry
does anyone tried to remove badges on the car yet? if so, how did you do it? what do i need to watch out for? and also when you removed it, did you have holes?
thanks
, Administrator Emeritus
The H, or in our case A may be attached by two rivets. I'll have to look into it.
The other badges are held on by two sided tape. You can remove them with dental floss, and cleaner wax (to remover the left over glue from the tape).
I did this on my Civic Si, and it looked nice and clean. I have been thinking of doing the same on my TSX, but have for now left the badges on.
mymothercountry
it's an A ... i wish it was JDM...but thanks for the advice...i just don't want to start and than end it up w/ holes in the trunk...cuz i don't like that whole idea of priming and painting over...but thanks
The other badges are held on by two sided tape. You can remove them with dental floss, and cleaner wax (to remover the left over glue from the tape).....
Yes -- oddly, that seems to be the way to do it.
Although I think the badges on the TSX are :king:
I'm just curious as to what the attraction is in removing badges? Is it for a smoother look, or just to be different?
A long time ago a badgeless car to me meant it was repainted & the emblems were left off. I know that's not the case these days.
All the badges give the rear of the car a clustered look. I am undecided about the TSX, so for now have left them on.
But with my Si, it looked much more clean (smooth) without the two badges (Civic, and Si).
Gives it a cleaner look. I'm takingmine off once I get off my ass to do it.
The front grille assembly is different for the Acura and Honda emblem. You'll need toe Honda grille assembly if you want a Honda emblem instead of an Acura emblem. Vice-versa.
Rear is the same, while the rest of the emblems can be easily sourced outside of the North Americas region.
owned ur ass
Has anyone ever seen any pictures of a tsx without emblems??? if so please post them, id like to see how it looks
1 - 14 of 14 Posts
