Hi all,I've just been stuck with a current battery issue that i've had. I've recently replaced the battery to a brand new 490cca one and I've constantly been checking the battery charge (with a car battery tester) and even after the battery change, it is still draining. Overnight, the car drops around 20% so I've tested if there is a parasitic drain and testing the amps, only 0.04/0.05 amps are being used when the engine is off. With the engine on and idling, the battery draws 14.1v and the voltage when the engine is off varies as per the charge (12.4-12.6~). Any thoughts on what the issue could be that's draining the battery.
I should also add that the car is a 2006 TSX.
