I have a 2006 acura tsx and I never had problems with it until a few months ago when the battery started draining I did unplug the Bluetooth module and It did help but not resolved the issue it is still draining the battery somewhere I have checked all the light fuses and everything seems to be working fine until I noticed something the controls on the steering wheel for the radio started acting funny I would press the volume up and insted it would go down and vice versa and sometimes it would just work fine so I started looking in to it and came across the clock spring spiral cable for the steering wheel might be bad and actually causing all the leaks I want to know has anyone came across a similar situation and actually changed out that part and fixed the problem it seems that the clock springs might be a defective part from acura 1st gen.
