1 - 3 of 3 Posts
I installed this aftermarket center panel... OEM panel lights were dim, the CD didn't work, and I needed BT.
Then you can use any aftermarket stereo with BT that you like. The HVAC auto function is squirrelly, so I have to set the temp and fan speed manually. Other than it works fine.
Before I switched the center panels I had a separate aftermarket BT installed, that was a little funky but cheaper than swapping out the whole panel.
1 - 3 of 3 Posts
