1 - 3 of 3 Posts
Looking to find a hose that can fit an Injen intake piping to the valve cover for smogging purposes. The oem breathing tube flew off since i added the p2r throttle body gaskets and spacer which made the oem breathing tube barely fit. I'm currently using a breather filter but it wont pass inspection. The outlet on the intake is bigger than the inlet on the valve cover.
Any help is appreciated and if you're selling an oem one, PM me!
Car Motor vehicle Vehicle Automotive air manifold Automotive exterior
You can always go to the dealer but they're pricey. I made my own with 1/2 inch hose and oem type clamps. You have to use a reducer like you noticed. It's roughly 3/4 to 1/2 inch, actually slightly smaller since it's metric but with the clamps it works out. I believe I got the reducer from a chain auto parts store. Or you may need 3/4 hose. It's been awhile so I forget but you can always measure the crankcase nipple and see what size it is. Best of luck!
Thanks for the recommendations! I will try my best to source these out and will give an update!
1 - 3 of 3 Posts
