Here's a video of what I'm working with. Battery recently replaced about a week ago as of 6/23/20, starter replaced a year ago, ignition switch replaced about a week ago. Starter relay replaced. I'm not sure what it could be, i have power for headlights, radio and AC but it's not clicking
When you changed ignition did you program the trasponder key to match ecu?
The ignition switch piggy-backs onto the key cylinder mechanism and is not associated with transponder.
Key reprogramming is not required after it's replacement.
It could be the starter. Check to see if you get correct voltage at starter solenoid when you turn the key.
What is the simplest way to reach the solenoid contacts? Thanks
