1 - 10 of 10 Posts
Slow but turns
hey i have this problem for a while now, and today i just went to autozone to get this code checked out. I bought a yellow bottle of "Something", and put it in my gas tank to clean up any dirty stuff in my engine. I ALWAYS use 92 Premium gas. The CEL comes on and off, it has been off for a long time for about 3 months and yesterday just came back on.
there was 4 things that could be faulty..
1: A/F Ratio Concern
2: Air leak near H02S (Heated Oxygen Sensor) Bank 1
3: Ignition System Concern
4: Faulty Catalytic Converter
Not sure what to do, i did some research and most of the people fixed their issue by adding a Defouler for their "Aftermarket Header/Cat.
I have a stock header/Exhaust, and the only engine mod i have is SRI and Pulley. I know my Intake is not the issue because back then I had my stock airbox and the CEL still came on.
Do you guys have any other suggestions for me? Im thinking that its about time i replace my Spark Plugs if that helps... what else should i clean/check? thanks!
PS
I noticed that my car smells like fart at the rear after i floor the gas pedal. the smell is not noticeable unless you go smell right at the ass of the car.
Is the light always on or does it come on and off?
Start with the easy/cheap fixes and go from there. Wish I could give more insight on your issue. Good luck.
Slow but turns
updated 1st post, yes the CEL comes and goes. it has been gone for a long time but it just came back yesterday.
I do have one question you may be able to help me with, when it comes on does it affect the vehicle performance? like the ECU adjusting the car to run rich/lean etc?
Sounds to me like its either #2 or #4, seeing how there is exhaust fumes involved. I check this out right away as there are carbon monoxide in the exhaust fumes, which can be fatal if inhaled for a period of time.
Since the CEL comes on and off, it sounds to me like its the cat. If there was an air leak (#4) i'd imagine that the CEL would be on all the time.
Slow but turns
Discussion Starter #5
thanks for that, i also noticed that during the cold weather, i can see a lot of my smokes coming out of the rear end of my exhaust when i accelerate from a stoplight. when i see other cars theirs dont come out as much, im not sure if thats the case for me having an intake but definitely something ill checkout on.
i only have 1k miles left of warranty on my car so ill bring it to the dealership and have them take a look at it
Sorry for bumping an old thread...did you ever got this problem fixed? And what did you do?
I have the same code...my cel came on about 2-3 weeks ago then it turned off three days later...two days ago it came back on then off last night...what could it be?
Looking for codes a few weeks ago came across a list of Generic OBD II codes.
It lists this one as: P0420 - Catalyst System Low Efficiency
1 - 10 of 10 Posts
