1 - 11 of 11 Posts
Recently, my center console light is out & also the airbag light come out once a while. So anyone have it fixed in GTA? dealer or Indy? How much it cost?
iVTEC no koe
Center console, you can DIY (there was a thread here about replacing some resistors), or just buy a used console 06+ to swap right in.
Airbag light, I would guess it's the driver side seatbelt buckle, ($67 from USA). You can test (with about 90% accuracy) by getting in your car, buckle up, then start the car. Confirm no Airbag light, unbuckle, check for the No Seatbelt light and Airbag light.
Seatbelt is relatively easy to swap out, disconnect battery, wait 5mins, unbolt 4 bolts holding seat to car (14mm if I recall), disconnect the wire harness(es). Remove the 1 bolt holding the seatbelt buckle, and the harness along with it, reverse to install.
Discussion Starter · #7 ·
Thanks, ordered it and is on its way now. So am I need to take out the seat completely? Or I can just move the seat all the way to the front?
iVTEC no koe
It can be done without taking out the seat, but make sure you have a wrench or ratchet that can fit in there AND have enough room when the bolt comes out.
One thing to be careful is (if you do it without taking the seat out), is that the seatbelt buckle has a notch in the bracket, that positions it correctly on the seat frame, within a hole. Tighten the bolt slowly to make sure this notch lines up with the hole.
Discussion Starter · #9 ·
Did that before? want to give me a hand? :p
iVTEC no koe
I just did it like 2-3 weeks ago. If you need help, let me know (PM'd you my contact info), but it is definitely WAY easier to take out the seat. Besides, taking out the seat is easy.
1 - 11 of 11 Posts
