1 - 2 of 2 Posts
Hi All,
Put a couple thousand miles on my 07 TSX now and have no problems with the car. Has a few little things it needs fixed (front 02 sensor issue) but I have a question about an inconvenient issue I am having with the charging system.
When coming to a stop, or in stop and go traffic I continually get a red battery light and a "Check Charging System" that stays for 3 to 5 seconds and then goes away. I have noticed that it comes on far less when the AC is on. Checked the voltage and it stays steady @ 12.5 volts when car is on and off. I am assuming it the early stages of an alternator going but wanted some insight if anyone else has had this issue.
Any help is appreciated
Discussion Starter · #2 ·
Just in case anyone has anything similar to this problem. Over the past two days the issue has become worse. I am going to change the alternator out this weekend and see if that fixes the issue.
1 - 2 of 2 Posts
