Hey guys so I just replaced my throttle body with a newer used unit as my car was not holding rpms at idle and it kept dipping when I came to a stop. This was exacerbated with the AC on, so I at first thought my AC was overcharged. However I started noticing this symptom without the AC running. So I suspected that it was the TB as we don't have an IAC valve in the air box but rather a sensor in the TB.
So I just swapped it for a TB out of a TSX with a 109k miles. And when I started the car the VSA and Check Emissions light came on within the first few seconds and the car was idling high. Wondering where to go from here. I'm reading that the idle relearn procedure is necessary when replacing the TB. I installed this part with the battery disconnected.
Is it normal for the VSA and Emissions system lights to be on while the idle relearn is taking place? I was somewhat startled by that and shut it off not long after.
I did spill some coolant below the TB when i removed the hoses. So I'm letting it sit with the negative battery cable off and the hood up to let everything dry before trying again.
Hooked up my OBD II gauge. Got 1 code for P2176, Throttle Actuator Control System Idle Position Not Learned.
