car specs
Acura tsx 05 6 speed MT
150,000 miles
Hello everyone! I’m praying that someone can help me out, I can’t figure out where this clunking metal to metal sound is coming from when I SLOWLY turn the wheel to either the left or right. Emphasis on slowly. This sound does not occur when I’m driving at regular highway speeds and some local street speed 12 - 25 MPH anything lower in speed while turning will make the clunking sound. Now to get into the details about 1 month ago I replaced EVERY component of the suspension system in the car. Just to clarify I changed the upper control arm, lower control arm, inner and outer tie rod, axle, lower ball joint, wheel bearing and wheel hub, shock and strut from Acura OEM 🤪🤑, and of course the stabilizer links again basically the whole front suspension everything was torque to spec double checked by me and my partner. On the rear I only changed the sway bar links, wheel bearing, and upper control arm as with the front everything was doubled checked and torqued. When I took the car to get it aligned and balanced the car was NOT making this clunking sound. After the alignment and balancing the car was fine and I was driving it no problems enjoying the 5 days of hard work after changing the suspension system. A few days after the alignment I started to notice the clunking sound. I have exhausted every possible culprit of this issue. I have check the brake system. I have again doubled checked the components I installed. I jacked the car and tried to recreate the clunking sound but funny enough when there is no weight on the front suspension it’s super quiet and smooth. Once I put the car on all fours 😏😂 and the suspension is loaded with the car’s weight turning the wheel slowly makes the clunking sound. I’m suspicious that the CV joint is bad but I get not vibration when going at highway speeds and of course it’s brand new so I doubt it’s bad but you never know 🤷♂️. I’m at work atm I will be posting a video link from YT of the sound the car is making in hopes that it can provide more information. Thanks to everyone in advance!
150,000 miles
