What is up fellow TSX'ers?!
SO lately in the FREEZING cold climate of Michigan... i've come across a few issues with my car.
1) My Ingalls ETD is stiff and squeeks alot
2) Coolant temp sensor is failing, the code/light has gone away for the time being...
My biggest worry right now...
3) Clutch is making a noise that sounds like "hoooooo-ngggggg" ... not a creaking and not coming from inside the cabin or from the pedal. Think of the noise as a rusted steel cylinder rotating inside of another steel cylinder and rubbing against it.
It happens mostly when i'm at slow speeds - 1st / reverse... when i'm near the end of letting the clutch out completely.
I've done some research and it seems it could be a TOB (throw out bearing) but my issue doesn't happen everyday or all the time, mainly on cold starts in the morning.
Any thoughts?
TIA!
Any thoughts?
TIA!
