1 - 2 of 2 Posts
Hey,
I got a new clutch a couple weeks ago. It fixed the issue I was having where most of my gears were not as smooth as they should be. It also fixed the grinding issue for the reverse gear and the first gear, all of my other gears did grind as well but very slightly.
However, a week or so after the clutch, my first gear is hard to go into sometimes, it could be the winter weather, I dunno. but my 6th gear is rough and my reverse has started to grind as well.
I don't know what the issue is.
I am hoping to God it is not the tranny.
It only has 155,000 kilometers, I bought it August 28, 2012 and the previous owner was the first owner and he babied it.
Anyone know what is going on ?
Thanks for your help in advance.
I would bleed the clutch slave again, I had the same problem after changing my clutch master ans slave on my accord. I ended up buying a reverse bleeder to get all the air out of the system. I had the same symptoms, hard to get into first when cold in the morning.
1 - 2 of 2 Posts
