1 - 2 of 2 Posts
I’ve had multiple circumstances where my CEL would come off and on and it would throw the code p0139
It would stay in maybe for a day or two and go away and do so for a while until recently it just stayed in for a good month
I thought it’d go away as usual but it hasn’t
Should I change my down stream sensor or up stream?? Or could it be something else causing it?
That code is for the downstream sensor. It's specific to the sensor itself, so not caused by poor fuel/air control or a bad cat.
Inspect the wires and the connector first, if no obvious problems then I'd just replace the sensor.
1 - 2 of 2 Posts
