Hey guys I read about the code and how it could of been related to corrosion in the sensor pins and/or the connector.
I took off my sensor in the bottom of the radiator, there was a bit of corrosion in it, the green stuff you see often in a leaking battery with corroded terminals. I tried to save the sensor by cleaning it with electric cleaner and a toothbrush, one of the pins broke off easily! The harness/connector the the car was perfect, just sprayed some cleaner in it.
I got this (I think) sensor at my local Autozone so I could drive the car while getting to ordering a Honda sensor, since I don't really like aftermarket sensors. Came with o-ring included.
Duralast/Coolant Temperature Sensor (SU6148) | 2006 Acura TSX 4 Cylinders 2.4L MFI VTEC DOHC | AutoZone.com
Got the new sensor in, applied a liberal amount of electrical grease on the sensor pin cavity and harness. Filled up with one gallon of the blue stuff, had to get another one to completely top off the radiator after a few heat cycles. Cleared the code and it never came back on, car does not overheat, fans seem to turn on and off normally. So I just kept that sensor in there.
