Never recharged an air filter before, and I tried googling for directions for foam filters but there are too many varied results, so needa make sure I do it right
1. Remove filter and spray dirty (blue) side with Uni Cleaner (I used Simple Green) and let the cleaner soak for 10 min. Rinse out from clean side and if still dirty, repeat this step.
2. After filter has been cleaned, let it air dry.
3. Once dry, spray the dirty side with 4 light coats of Uni Oil, 20 minutes apart. After all coats have been sprayed, let the oil settle into the filter for a couple hours (clean side down) and reinstall
Anything wrong with my process?
