1 - 2 of 2 Posts
Just recently picked up a TSX and there is an issue with the cruise control. It works, kind of... Here is what it is doing now.
Resume/Accel: Doesn't work at all.
Cancel: Does not cancel, but will Set/Decel when held.
Set/Decel: Works fine.
So the Cancel button is replicating the Set/Decel function, I have no buttons to cancel (clutch and brake both cancel my cruise though), and no buttons to resume or accel.
I've searched but found nothing except someone having the same problem in their 03 Civic SI but no answer there. Anyone here have any ideas? Would be greatly appreciated.
I had to replace my cruise control switch on the steering wheel when the on off button broke... it was very easy to do. I did not have the problems you describe though... but i would assume that you are going to end up replacing the switch to solve your problems.
1 - 2 of 2 Posts
