LED Tails on without lens
Okay, well I've been able to get some pics of them lit up.
Having some problems with the lenses though. I've put VHT nightshade, then clear coat. When I lit them up with the lenses on I suddenly found that one of them has some very weird residue on it. It almost seems as if there are hundreds of snow flakes stuck in the lens. Not sure what it is. I think I'm going to have to give them a good sanding & redo the spray. hopefully its the spray job and not the lens themselves. If any has experience with this happening let me know!
Pics:
LEDs off
Running lights mode
Brakes only
Running & Brakes
Signal only
Running, brakes, & Signal
Reverse rings only
Reverse rings & High power LED bulb
