Hey all,
This is a short description of my experience with a problem I had a few weeks back. Excuse any mistakes as I'm multitasking.
I was driving nearby my home when my engine started vibrating oddly. I thought it was the A/C, so I shut that off. Over the period of 30-40 seconds it got progressively worst. I was only about a mile from home, so I decided I would try to make it back so I could park instead of having to get a tow.
As soon as I got to the next stoplight (and then tried to accelerate), my engine was barely managing to chug itself along.
CEL turns on.
I got her home, turn the car off and started her back up. Still the same problems.
My friend came over with a scanner and we got "Cylinder #4 Misfire". Oh ****, I didn't want to deal with this. The car was warm, so we opted to wait a few hours (~4 or so) until pulling the spark plugs to see their condition. The previous owner claimed he changed them 15k ago, but I didn't really believe him without a receipt.
Before pulling the plugs though, I switched two of the ignition coils. I didn't know the orientation of the cylinders, unfortunately... so I guess that they were (4,3,2,1) [passenger side - driver's side]. It is actually the opposite. I was hoping to switch the coil on #3 and #4 to see if the problem would follow a bad coil. It didn't because I swapped coils #1 and #2 without knowing it. At this point I should have swapped the other two coils, but I didn't.
I went to get new spark plugs and changed them. This was more of a piece of mind thing. I had a receipt, and I made sure to put anti-seize on them. Now I KNOW my plugs are new. The old ones didn't look good...
Problem still persisted. This time, I decided to switch the correct #3 and #4 ignition coils (the correct order is 1,2,3,4 from passenger to driver). The problem followed the coil. My friend's scanner read Cylinder #3 misfire.
I ordered a new ignition coil off amazon, installed it, and all is well again. So glad that it was not a more severe problem. Hope this guide may help someone who has a similar problem.
P.S. In my past experience, a bad spark plug or coil may be more intermittent. Mine just flat out went dead. The vibration may have been caused the imbalanced from only having 3 cylinders operational.
CEL turns on.
