21 - 37 of 37 Posts
WAT DO?
I checked the part numbers, The newest coil is only used in the TSX/RDX. The older part number which was superceded is only used on the TSX.
I ended up shelling out 130$ for one at the Acura dealer... rip off!
All is well now though.
helpful
I received the code P0304 sunday of course Acura was closed so had to wait till today. Acura wants to charged 600 bucks for 1 ignition coil replacement so I bought the coil for 95 at advance auto parts put it in and now I'm not shaking in my ride. :party:
Same as above ^
Joined the club just to say how thankful I am, my first post:
I've owned my 05 TSX for almost a year now with zero problems. It now has 96k miles.
Just the other day, I was out driving and all of a sudden, when I went to accelerate at a green light, my TSX started sputtering. The check engine light then started to flash. I pulled over, turned off the car, turned it back on, still sputtering.
I pull out my cheap OBD2 code reader from my trunk and the plug it in. It throws the P0304 code. I google "tsx p0304" and find this thread. I run down to the local parts store and pick up a ignition coil for $95 out the door.
The installation was much easier than I expected. Unscrewed (4 screws) the black plastic plate. Unplugged the coil closest to the driver side. Unscrewed it and pulled it out. Placed in the new ignition coil and put everything back. Took about 10 minutes.
Bottom line, this thread easily saved me tons of time and money! Thanks, folks!
Mine's done that twice now on two separate occasions. It's a simple replacement. Part does not cross-reference with a Honda part (that is usually my first route when looking for an OEM part), so you would either get an OEM one from the Acura dealer ($98 where I am located) or an aftermarket one somewhere else.
They seem to fail with no set pattern of mileage that I've noticed, so I just replace the one that goes bad instead of replacing all 4 at the same time. If you have the money to spend and want the peace of mind, you can certainly replace the 4. What I do is if I keep a spare new one in the garage, or tuck it in to my spare tire well if I'm going on a road trip so I can replace it on the fly if it ever fails when I'm a ways from home.
This Fixed My '06 TSX
Just performed this same fix on my '06 TSX. This past Saturday I went to accelerate from a stop at a red light and the car started sputtering and hesitating. The idle was low and VERY rough...the whole car shook. Ran a diagnostic and got the P0303 code. Replaced the ignition coil on cylinder 3 and she runs like a champ again!
Quick note: posters above are correct on the FIRING ORDER being 1-3-4-2. But the cylinders themselves appear to be ordered 1-2-3-4 passenger to driver. I got he P0303 code and I swapped out the coil 3rd from the passenger side and it did the trick.
Kudos to the OP and others! I just saved myself about $450 at the dealer. The coil cost me $88 at Advance Auto Parts and I purchased a set of NGK Iridium spark plugs for $9.99 a piece. The whole job took me 15 minutes.
pedal damn it
2005 TSX w/ 92,600 miles: Cylinder #2 Misfire - Solved!
Same thing here.
Driving home from work last week, suddenly car started shaking, bad!
Got it home and pulled this code:
Searched "Acura TSX cylinder misfire" and this thread pops up. :tu:
Pulled the old spark plugs out:
Installed brand new NGK 6994:
Although I was in need of new spark plugs that didn't solve my problem.
In fact, more codes popped up! Along with my initial code of P0302... now I had P0301 and P0303 to deal with.
Went over my work and everything checked out so I knew that the culprit was most likely a bad coil plug.
Most likely coil plug #2 since that's the cylinder that was initially misfiring.
However, why did the other codes pop up after I changed the spark plugs?
Could it be that now the other coil plugs were going bad as well?
I could've started switching coil plugs around to see which one exactly was causing the problem, but I thought to myself that if one coil plug is already bad, then how long before they all go bad?
I wasn't gonna drive around and stall in the middle of nowhere to find out so I ordered 4 brand new Acura coil plugs online.
Parts arrived yesterday.
Out with the old:
Installed 4 new coil plugs and PROBLEM SOLVED!!
Coil plug part #:
All codes are cleared and car is running like a champ again.
Thanks again to this thread which originated in 2011 and to this DIY:
http://www.tsxclub.com/forums/1st-gen-engine/47600-diy-changing-spark-plugs-step-step-pics.html
Sure glad I got this mess all sorted out because I just received my DMV renewal the other day and my vehicle is due for a smog. :eek:hsnap:
Same thing just happened to me. 155,000 km car started to shutter and felt like it was going to stall.
Figured out that cylinder 3 that was the cause, so I replaced that ignition coil.
Cars running much better now! hopefully that was the only problem.
Question for you guys though. The check engine light is still on (solid, not blinking), will this clear by itself or do I need an OBDII reader to clear it?
Thanks
Hello,
Quick question and probably a dumb question. How do you read the number [Passenger to Driver] 1,2,3,4 or 1,3,2,4, etc... Let me know because my coils crapped out not long ago. In January, driving to work in the morning and my engine started shuttering. Pulled over and turned off and on and the problem persisted. Luckily i didn't get on the freeway and found the nearest mechanic. I was told by the mechanic that #4 misfired and asked if i wanted to change one or change all. I decided to change all since if one failed, the rest isn't far behind. Man..that cost me a some money. Just recently, my engine started shuttering again while going to work. Luckily i was close to my train station where I usually park and there was a mechanic shop. The mechanic said #2 & #4 misfired. WTH? I changed it not too long ago. Told him to change 2 and 4. I guess I'll be eating instant noodles for a while! Everything is now running smoothly but i'm getting paranoid. I have a funny feeling 1 and 3 will fail. Don't know what brand the coils were from the initial change but i know the last mechanic used Delphi as stated on this expensive invoice. I observed the mechanic and it looks easy enough to change and will order my coils. The only thing I'm totally lost is which is 1 & 3?! As stated early, what is the sequence, from Passenger to Drive?
Hello and Thanks
Joined the club just to say thanks to all for the info and including parts number as well I am, my first post:
I've owned (wife) 07 TSX since new with zero problems. It now has 114k miles.
This morning she call me describing exactly the same predicament.
I went to her work to troubleshoot the car with my OBD2 scanner and It throws the P0303 code. I google "tsx p0304" and find this thread.
I too, went and order it from amazon as one thread had indicate with a link, Thanks.
Order the coil for $58, that is tax and one day shipping included, be here tomorrow.
Incidentally, in my household we also own two Honda Fit; the first gen. 2007 with 147K miles, which started misfiring last year "2015" as well, no CEL thou, replaced #4 coil pack, and it fixed it. And at the end of 2016 stated misfiring again so I decided to replace the other 3 coils, ordered from Rockauto.com $89. It should good for another 100k mile, I hope.
Now, the 2 gen Fit with 139K the only problem has been the A/C blower motor. replaced it twice already.
BTW, since last year, the mpg on the TSX has drop to 19 mpg and I know that the average was 29 mpg .
I just haven't had the chance to read up or troubleshoot it to figure what the problem is.
I have notice that the temperature gauge needle only reads 1/3 of the gauge and I believe the needle should be at least right or just above the middle range.
In any case when I do the coolant flush I would be replacing the thermostat and see if that does it.
Again, thank you all!
Sorry to bring this back but I want to add a few more theories to what can cause the misfire. I have been having a misfire on #3 I changed plus, coils and it still would come back we started looking at compression and other possible causes. After everything checking out he said and it coming back clear it came down to either a faulty ecu or a that I need to flush/clean my injectors. So I went to Honda and had them clean em out. Since then it feels smoother and I haven't had a check emissions light Since, it's all new so I will keep an eye on it but just a heads up for another possible cause of the cel
Same thing here.
Out with the old:
Coil plug part #:
Guess a less expensive way to go would be to buy two coils (preferably online from an Acura dealer). Replace the malfunctioning one, and have a spare readably available for the next failure. When it fails, buy another "spare"... That allows you to get the most out of the original coils without being "down" for more than your commute home (unless you keep your scan tool, tools & spares in the trunk).
Awesome diagnosis, wolverinept! Glad it worked for you, and, that it wasn't too $$.
Just a point of useless clarification: Cylinders firing order I believe is actually 1, 3, 4, 2. ;)
Hi guys,
First thanks for the info. Great time saver, straight to the point in description.
Cylinder order
Left to right (starting on the passenger side (facing the vehicle)): 1,2,3,4
what do I do if I get Misfire in cylinder 2,3,4?
Do I change all spark plugs and coils????
Hey all,
This is a short description of my experience with a problem I had a few weeks back. Excuse any mistakes as I'm multitasking.
I was driving nearby my home when my engine started vibrating oddly. I thought it was the A/C, so I shut that off. Over the period of 30-40 seconds it got progressively worst. I was only about a mile from home, so I decided I would try to make it back so I could park instead of having to get a tow.
As soon as I got to the next stoplight (and then tried to accelerate), my engine was barely managing to chug itself along.
CEL turns on.
I got her home, turn the car off and started her back up. Still the same problems.
My friend came over with a scanner and we got "Cylinder #4 Misfire". Oh ****, I didn't want to deal with this. The car was warm, so we opted to wait a few hours (~4 or so) until pulling the spark plugs to see their condition. The previous owner claimed he changed them 15k ago, but I didn't really believe him without a receipt.
Before pulling the plugs though, I switched two of the ignition coils. I didn't know the orientation of the cylinders, unfortunately... so I guess that they were (4,3,2,1) [passenger side - driver's side]. It is actually the opposite. I was hoping to switch the coil on #3 and #4 to see if the problem would follow a bad coil. It didn't because I swapped coils #1 and #2 without knowing it. At this point I should have swapped the other two coils, but I didn't.
I went to get new spark plugs and changed them. This was more of a piece of mind thing. I had a receipt, and I made sure to put anti-seize on them. Now I KNOW my plugs are new. The old ones didn't look good...
Problem still persisted. This time, I decided to switch the correct #3 and #4 ignition coils (the correct order is 1,2,3,4 from passenger to driver). The problem followed the coil. My friend's scanner read Cylinder #3 misfire.
I ordered a new ignition coil off amazon, installed it, and all is well again. So glad that it was not a more severe problem. Hope this guide may help someone who has a similar problem.
P.S. In my past experience, a bad spark plug or coil may be more intermittent. Mine just flat out went dead. The vibration may have been caused the imbalanced from only having 3 cylinders operational.
You could change plugs and coils if you want to save time and don't mind spending the money. If you you want to save some cash I would suggest replacing the spark plugs (NGK Iridium) first and see if that solves your issue(s). That's the cheapest route.
21 - 37 of 37 Posts
