Yea unfortunately California and Los Angeles county is well known for car theft so regardless on what you drive or where you live surveillance and precaution is a must, if you care about your vehicle getting stolen. Also keeping your car from car meets will prevent people putting air tags on your car and following you home.
unfortunately my battery light turned on so I need to replace the alternator before I can test that because I’m also curious. The kit is cool because it doesn’t just read the key is nearby to start,you need to swipe the key fob over the antenna in order for it too disarm (two beeps) and then you can start the car. Once you turn it off you swipe it again to arm the system. If you don’t know where the antenna is, it may be hard to start the car but mine is unfortunately in the most obvious place.
no module 2 of the 3 green harness plug into the back of the radio the radio even notifies me if a door is open but disables the top clock that’s right above the emergency light switch. I may take that out to install a enginetix oil pressure gauge to replace the one I have and have use of the ac vent again.
