Please?!
Symptoms:
- Very tough to get into 1st from a dead-stop (car warm or cold, doesn't matter).
- Reverse always grinds really bad.
- 1-2 and 2-3 shifts feel notchy, not smooth.
- clutch grabs really well, no slippage. (thankfully).
- OEM clutch, 215,000km.
- Clutch pedal clicks on way down, and creaks/squeaks on way up. Bracket is NOT cracked.
Notable:
- With car off, shifts into any gear are butter smooth no matter if clutch is in or out.
- If I pump the clutch 2-3 times with car on, the shift into 1st or R is smooth like it should be. This happens 100% of the time if I pump the clutch.
- Checked clutch fluid - looks slightly dark but is between MIN and MAX levels.
- Have not tried bleeding the clutch lines yet. Slave and Master cylinder are still stock, never changed.
So... what to check/do and in what order?
THANKS!
Symptoms:
Notable:
THANKS!
