Removal
1. Make sure you have the anti-theft code for the radio and the navigation system, then write down the customer's audio presets.
2. Disconnect the negative cable from the battery first, then disconnect the positive cable.
3. Remove the drive belt.
4. Remove the auto-tensioner.
5. Disconnect the alternator connector (A) and BLK wire (B) from the alternator.
6. Remove the three bolts securing the alternator, then remove the alternator.
Installation
1. Install the three bolts securing the alternator.
2. Connect the alternator connector (A) and BLK wire (B) from the alternator.
3. Install the auto-tensioner.
4. Install the drive belt.
5. Connect the positive cable to the battery first, then the connect negative cable.
6. Enter the anti-theft code for the radio and the navigation system, then enter the customer's audio presets.
7. Set the clock.
Installation
7. Set the clock.
