Hi, have recently been doing a P&P job on my RBC I/M to accommodate the ZDX big bore DBW T/B. You have to buy an adapter plate to make this work, due to the fact that the ZDX has a different bolt down set-up.. I bought mine from P2R (#P384) there are supposedly others out there, but I don't know by whom, and didn't research any further...
Anyway, the ZDX T/B has an 80mm inlet dia, and a 70mm outlet. I decided to open my RBC inlet up to the required 70mm. I thought about how i could go abouts doing this.. Found some nice tools at my local hardware store. For the opening of the I/M inlet I used grinding wheels, that fit on a rubber base, made for use on a drill machine. (Shaft dia. 6mm) The wheels come in various grits, so I grabbed a handful of each and went to work. Still waiting (almost 3 weeks now) for the adapter plate to arrive so i can do the final grind/sizing, but this is what it looks like at the moment:
Grinding wheels from coarse to fine:
http://imageshack.us/a/img401/9199/3waf.jpg
Wheel attached to the rubber base:
http://imageshack.us/a/img842/5641/7y2v.jpg
Inlet opened up, awaiting final touches:
http://imageshack.us/a/img842/7240/fiq0.jpg
I then attached my P2R (no this is not a cheap ad for the company, though I do much like their products!!) Thermal I/M gasket with 2 pcs 8mm bolts, 1 per side, and a handful of 6mm bolts to keep it firmly in place while porting/polishing. I then went ahead and ground the runners open to the size of the gaskets, +/- say 0,5mm. Here i used an array of cutting/grinding tools. For the rough cut, i used my dremel, with cutting tools from "Proxxon" (They are WAY better than the cutting tools dremel has to offer). make sure, if you go this route, to buy tools with large open cutters. Cutters that are cross-hatched are too narrow and tend to gunk up quickly, the spaces fill with aluminum fast as hell!!
I/M runners opened/ground out to the size of the Thermal gasket:
http://imageshack.us/a/img89/3205/r6kt.jpg
Close-up:
http://imageshack.us/a/img534/5189/1l96.jpg
Dremel/Proxxon tools.. (You will require a smaller dia. chuck for the proxxon tools, being their shaft is only 2.3mm compared to dremels being 3.0mm:
http://imageshack.us/a/img833/8503/z9em.jpg
Gunked up cross-hatched tool:
http://imageshack.us/a/img837/2691/lud3.jpg
For those hard to reach places, and furthe down the runners/into the plenum of the I/M i made these tools: Took a 1m piece of 3mm copper round material,, which i could cut into various lengths, depending on how far i wanted to reach. i then applied some double sided tape to the end and stuck some sanding paper to that. You can make different shapes, using the tape. For the most part, i used cylindrical shapes, but to make a tapered tool is quite easy too: Just wrap some tape around your 'dowel', then a few mm back, add a narrower piece, and do this a few times till you have a christmas tree form. Then wrap your sanding paper to that in a spiraling motion. Tape the loose end down from the inside (Loose end) and presto: For the cylindrical ones i just left the loose end dangling... makes a bit more noise, but the rotational force keeps it from unwinding.. Too, when the sand paper is finished, you just tear a strip away and can get right back to work without having to reapply the paper.. (Beware that it is 'wound' in the same direction as rotation!!!)
http://imageshack.us/a/img812/5999/ty8n.jpg
http://imageshack.us/a/img585/7941/05ae.jpg
I imagine, if you so wanted you could also apply some scotch brite to the tool for a final finishing.. still doing some tinkering around, thinking of maybe using some valve seat gringing paste to do the final polishing... 2000 grit wet sand paper would be worn out within seconds using the dremel..
Oh, one more thing: I also have the flex shaft tool for the dremel.. it is/was the ultimate helper!! the grip is much narrower, easier to get in to those tight places..
I have done pretty much the same thing on my head, opening the channels to the valves, so they 'fit' the gasket.. also bolted into place, to keep it from moving...
Mounty
Close-up:
Mounty
