Not sure if this is a re-post, but I couldnt find it.
Reason I did this is because I needed to install an AEM wideband and there is a second grommet that I used for this, but the same steps can be used to replace the secondary o2 sensor.
Jack the car up with stands high enough to get to the secondary o2.
1) slide the front passanger seat all the way foward
2) pop the plastic caps of the seat rails on the back and remove the two bolts
3) slide the seat all the way backwards and remove the two front bolts
4) Slowly and carefully tilt the seat backwards(becareful of the SRS and motor wires)
5) you will see a small black plastic snap and a little access spot in the carpet, remove the snap and peel back the carpet you will see the connector and the grommet for the o2 sensor.
6) disconnect the sensor from the connector and pop the grommet out.
7) go under the car and remove the o2 sensor and feed it back into the car
8) your all done just do everything in reverse to put the new one in!
No pictures for this one but its pretty self explanatory
