Does anyone else feel the steering "channel" and "volume" buttons should be switched?
I am referring to the controls for the radio on the steering wheel. The channel or track buttons are on the inside while the volume buttons are on the outside. This makes the volume buttons the most easily accessible and easiest to find as they are the closest ones to your hand while you almost have to look to hit the track buttons and stretch your thumb to reach them.
This is really annoying to me and makes zero sense since the channel/track buttons are used MUCH more frequently than the volume buttons. Once you've set the volume, you're good for the most part. If I want to suddenly mute the radio it is much quicker to simply hit the power button on the radio and turn it off. The channel/track buttons are used almost every few minutes unless you are ok listening to the entire playlist in order and are in the mood to listen to every one of those songs at the moment which is rarely the case.
Is there any way to reprogram them?
