I got 2004 acura tsx and the right rear door won't lock manually or electronically. I thought it might have been the actuator since it won't lock with the key fob but when I manually push the lock pin down, the door still won't lock. The door still opens from outside Even when I push the lock pin down. Any idea to what it might be?
You may try using a lubricant.A silicone spray lubricant is best suited for car door locks. Ensure that you buy a lubricant with a spray straw. This is vital to lubricate the deeply-positioned parts of the locking system. Further, this type of lubricant is impermeable to water and sticks to the surface for a longer period.
Thank you for this remedy. And kindly, what would have been the cause? I have had such issues, probably water entering into the system, or dust, and probably insects. Anyone? Any thoughts on this?
