Whaattss up?
I will try explain my best what the issue is:
DOESN'T WORK:
1) Remote key to lock/unlock doesn't work, unless if I first open my door with a key, then can unlock the rest of the doors with remote.
2) Bottom door light, is not turning on. I checked the bulb, its fine.
3) If drivers door is not closed properly (shut), it will not display in dashboard that the door is still open.
WORKS:
1) Power windows, locks and mirror works with the touch of a button on the door.
I was thinking its either grounding is not complete, maybe fuse or door lock actuator. I searched but couldn't find diagram for the door lock actuator to check if that is the issue.
Any input is appreciated, thanks!
Un-Civil Engineer
Sounds like you need a priest!
I can't explain the light not working or the door open indicator on the dash, but the locking issue sounds like the actuator. I had that issue repaired under warranty a few years back.
Good luck with the rest!
Gotta take a Dookie
its your door actuator. I have the same issue as #1 but not the rest. our door actuator is made out of cheap plastic so it does go out and needs to be replaced. You can find it for around $30 for the part on acuraoemparts.
Whaattss up?
Discussion Starter #5
Thanks all for reply, I will look for actuator. Any ideas about the light and sensor on dashboard?
