Hey everyone,
In my 07 TSX, I noticed recently that the driver's side rear window won't roll up from the master control. Usually, there's a pretty audible click noise to let you know that the window motor is being engaged to roll the window up. Right now, I only hear that when I roll the window down.
At the rear driver's side window control, I can roll the window up and down no problem. I've tried replacing the master window switch, I've checked the fuse and tried swapping it with the rear passenger side window and there was no change.
I'm not sure what to check next, I was a few times, able to roll up the window from the master control when I opened up the driver and rear driver side doors. I was thinking this perhaps has to do with the link that goes through the pillar between the doors? Not sure.
Any advice is appreciated. Thanks!
It's common for the master switch assembly to fail on 2003-2007 Accords. The 2004-2008 TSX is mechanically and electrically similar to an Accord
Thanks, I've already tried replacing the master window switch. It was original and seemed like a good place to start.
I am having issues with my windows only the driver side goes up and down all the others wont come down ....how can i fix it ?Any Suggestions
