TSX Club,
Has anyone tried these out?
04 06 Acura TSX JDM Crystal Clear Fog Lights Lamps Kit | eBay
Kindest Regards,
Kindest Regards,
Here's the threadDoes anyone know of a guide to rig the fog lights to the parking light / headlights so there isn't a separate switch for them?
Kindest Regards,
I think your best bet would be to take it to the shop and get it wired.Thanks for the replies!!
Anyone know if it comes with new 'bitch clips' or whatever? I am new to modding the TSX.. Do they need to be broken off or whatever to be removed, or are they reusable?
Thanks again,
Thank you!The bumper clips shouldn't break off, as stated, use a flat head to pop them off.
If you get the K2 kit, save yourself the money and wire it yourself.
The kit can't be easier to wire.
Everything is labelled, too.
There's literally 3 things you have to wire from the K2 kit (since you're doing the no-switch method).
Power wire. It already comes fused, all you do is attach it to the positive battery terminal.
Ground wire. This goes to any ground point on the car chasis. They're everywhere.
Trigger wire. This would have to be spliced aka tapped into your parking light wire using a "t-tap" connector or splice connector. They're idiot proof.
Obviously the last step would just be to connect the fog light connectors to the actual fog lights.
Not so hard is it?
