SITUATION:
So i'm having a slight issue, whenever i take a sharp turn or just a slight turn such as pulling in/ pulling out of the drive way, going up in car garage,I get the ENGINE OIL LEVEL LOW, now my oil according to my car is at 50%, i just added a QT of mobile 1 synthetic like a week ago, and i use 4.5 qts on oil change done 1000 miles ago (synthetic suppose to last 5000) so i shouldn't have low engine oil.
QUESTIONS:
1.Am i burning oil at 56,000 miles?
2.What can i do to check if i can check if im burning oil?
3. could it just be a bad sensor? like the vtec soleniod or something??
4.why does it happen when making turns?
COOLANT ISSUE: I Smell coolant from my engine, i checked for leaks, NONE, i flushed added new coolant, still draining and coolant smell.
1. Where do i look if ive checked HOSES (top and bottom) and ive checked throttle body area since i did the TB MOD????
ANy help, suggestions will be greatly appreciated, ive searched on this topic before no answers, problem went away now its back :-/
QUESTIONS:
