my engine light has been blinking and the whole engine down to the exhaust has been shaking and rattling. things that its defiantly should not be doing, i changed my oil and my spark plugs thinking that would help solve the problem, it didnt. Help?? please
check the mounts, also that the O2 sensors is connected, since you said its shaking at the exhaust lift the car and check there. take it to auto zone if you can they scan your car for free
My car whines
yea you should get that engine check light code read asap and try not to use the car for the time being. before you did the oil change, did you check to see if it was low? the timing chain tensioner uses oil pressure to keep tension on the chain so if you're severely low on oil it can cause the chain to skip and cause the engine to misfire.
