HELLO
anyone with a annoying engine vibration? (mostly at idle)
i can feel the whole front end/dash/steering wheel vibrating!!!!
mine occurs cold(real bad) and hot......gets better after a few hours driving.
note: car is a auto trans,if i pop it into neutral at a set of lights,this helps a very little bit(taking load off),
i have not yet pulled the plugs,but see another forum user re-gapped his as they were not gapped properly at the factory....claims car now runs smoother.
sure feels like a bad plug,vacuum leak or similar.
if anyone has same exerience or good detailed info,i would appreciate it.
odometer is just over 16,500 kms
thanks
CM :donno: :donno:
thanks
CM :donno: :donno:
