1 - 3 of 3 Posts
Hi guys,
Wondering if anyone knows if TMPS sensors work with Enkei GTC-01 rims.
This might be a dumb question, but I see two valve stems for each rim, so does that mean I need two TMPS sensors per rim? How come there are two stems?
Thanks.
Pally777
未来へと
only need 1
as far as why are there two valve stems, not sure...I would like to know as well.
Nitrogen.
Some people put nitrogen into the tires instead of regular air. I think nitrogen isn't as sensitive to heat so you always have a constant psi in your tires. One valve is for putting in the nitrogen, while the other valve is for sucking out the air. That way you can put in close to 100% nitrogen, while if you only had 1 valve, you'd be stuck with a mixture of air and nitrogen because air is always present.
1 - 3 of 3 Posts
