So a while ago I got a check engine light - had the code scanned (can't remember now what it was) and it seemed to indicate I might need a new radiator fan switch.
So I found this Mishimoto switch that claims to kick in sooner at lower temp. - great. Problem is the seller indicated it was compatible with my 2006 TSX but the actual packaging does NOT specify for '06 TSX. However I see this other site also says its compatible. Mishimoto® MMSWITCH-CIV-06 - Acura TSX 2006-2012 Fan Switch
I wanted to get it installed ASAP since I've been putting it off and I don't have a garage or lift (and its winter) to do it myself. So I ask the neighborhood mechanic to install it for me at his shop and do a fluid flush while hes at it - and he says it doesn't fit and just does the antifreeze flush.
Does anyone have this part installed on an '06-'08 TSX?
This is what I have:
Thanks!
Thanks!
